Thanks, I am very happy how it turned out.
The cement top weighs 100 pounds.
The Big Green Egg weighs 162 pounds
The table is only 36 pounds it is really light.
The table is very sturdy and I am sure I welded it in more places than I needed to.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
