Old 11-30-11, 06:17 PM   #140
Originally Posted by Ko_deZ View Post
I do think this is a very interesting project, even though I have very little faith in it ending up as a cost-efficient solution.
I'll do my best to help you to see the error of your ways...
If you need any help with the arduino, let me know.
Very generous of you. It is very likely that I will need help on that part.
Btw, pretty much all passive houses that where built 15 years ago (as experiments), seems to be getting humidity damage and rot. I talked with a few people that helped putting those houses together. Not much has changed in the building process. Some materials have gotten better, and the humidity block quality and awareness has improved but that is about it. I am dreading how it will end with my house after the next 20 years.
So, I take it that your house is a passive house? When was it built?
When you say "humidity block" do you think that is the same thing as "vapor barrier"?
..and what part of Norway do you live in? I'm curious about the Heating Degree Days there.
