Old 01-16-15, 01:18 AM   #2
NiHaoMike
NiHaoMike's Avatar
Use an OpenWRT router or similar to send the start signal via WiFi. You can use Wireshark to reverse engineer the protocol. Use a comparator or ADC to check the battery bank voltage, low pass filtered with at least 10 seconds time constant so a voltage sag due to inrush doesn't trigger it.
philb (01-16-15)
