Those are some GREAT links AC Hacker! Thanks. I really like that Make article. Although, I do think it would be more efficient if it had flow going like the commercial units that use 90 degree cross flow. I'd imagine that it just makes better use of the sheet metal between the intake/exhaust. Do you have any examples of the 180 degree flowing design? With only a small amount of modification I think you'd really have a nice heat exchanger, and it could be made CHEAP too.
