Well, I had a bit of a hiccup with the system over the weekend. I actually wasn't even home, but came home Sunday night and the blower was blowing. However, I also saw that the damper in the kitchen wasn't pusheed up as high as it normally is. So, I went to check things out and sure enough, one of the fans wasn't turning. I'll have to pull it out and see whats going on.
