You need to add up your kWh used over night, so you can come up with
an adequate size for your PV array.. If you have 5 hours of good sun on the PV
array and it's a 100 watt panel (0.1kw), it's going to put a possible 0.5kWh charge into the batteries..
And, if it's cloudy for a couple of days, will your pack be able to supply the loads?
Or will you be able to use the grid or the Honda to charged up the pack?
I would buy at least enough PV to replace all the juice lost during the night,
plus about 25%, for losses and in case of clouds..
Here's a pretty nice panel store..
Solar Panels
I'm looking at some of those cheaper thin-film panels that are coming out in May.
Not sure if I'll get them yet, since they are so large and heavy..
Now that that the floods have done a job on my basement, we are looking
at major cost to repair, add pumps etc..
