Old 12-20-13, 11:36 AM   #4
stevehull
Steve Hull
Acuario,
There is a point where making the evaporator too large and you loose a lot of efficiency. Take this to the extreme to make the point.
Imagine a standard 36000 BTU (3 ton) air conditioner with a standard evaporator. Now, put in place an evaporator the size of a house. The gas that fills the evaporator has expanded almost to room pressure and it has long given up all the latent BTUs. Yes, it is cooled slightly more than say an evaporator the size of a kitchen and only slightly more than an evaporator the size of a bed.
The point being that the pressure - BTU - cooling curves are not linear, but are S shaped. Evaporators work on the linear part of the sigmoid curve. Beyond that and the change in pressure vs temp curve goes rather flat.
Also, imagine the volume of refrigerant you would need!!
Does this make sense?
Steve
