Its plumbed and running , the outside exhaust outlet front edge reading was 21 to 25 mph the middle around 17 gives an
average around 20 mph the same as the 6 to 4 adapter average 154 CFM (or there about)
The iPhone makes for a tricky post !
0.3*c outlet temp 16*c / 61*f inlet (outdoors)
plumbed the hose and taped it tight
Exhaust is wrapped with a old mummy bag then plumbed it to drain condensate in a water cooler bottle.
Weighs 85 lbs
Set to blow hot air up toward the doorway
Tomorrow will make the cardboard vent and block the middle of the doorway to get flow separation.Have not noticed a back draft yet , there is no door hung
Temp downstairs was 29*c or 84* upstairs 24*c 75*f
Had it set a 87* to test. Upstairs can just hear it turn on/off , down in the room its a pretty loud low frequency sound with a added compressor note.
Inlet ? outlet tests done at about 6 pm
61* / 16*c outdoors infiltrating air
32.5*f / 0.3*c house exhaust taken from the exhaust vent outside the house.
Hot air vent was 145* to 140*f or 63* to 61.5*c
Tonight's low prediction 8*c / 46.5*f the weeks average is 5.5*c
Do single phase compressors make their highest COP at real warm temps too ? Read they made cop 5 from about 10*c to 12c not sure if it includes higher temps as the chart was unclear.
I read 3 phase make theirs highest cop up at 35*f ? due to low compressor power draw. Thats what some pdf file says anyways , The pdf link
https://r.search.yahoo.com/_ylt=AwrT...naWE__qpgicvk-
