Thanks oil pan 4 , havent done the math on that or pricing the pour.
Still getting a grip on the process and thinking on plans. It will be a small rancher.
Im going to price out a 1100 sq ft house and a 1350
6 divided by 1100 is 183 cu yards then I add inside walls I'll work on that math
1350 sq.ft is 225 cu yards plus the inside walls
Watched some instructional videos out by the manufacturer and it looks easy enough.
Current project I removed a 4 ft garage extension with a deck ontop from the front of the house and am remounting the garage door flush with the house.
This work was done in the last 3 days.
It was a rot problem not anymore. Swapped out the 2x4 wall for a 6x6 outside wall. It seemed a little precarious with the 2x4's .. its covered in 3/4" plywood for its structural strength.
The door is going and a 3'6" inch slider window is going in place.
