That's like asking will it be worth it to buy a car ?
would it be worth it to buy new runners ?
As for the car if a person is walking all over hells acres and bumming rides to no end then yes a car is 'worth it'
As for the runners if the previous pair is worn out or inadequate then yes new runners are worth it.
As for the Propane conversion on a generator is it 'worth it' depends on if you want to save money on operating it for prolonged periods of time (a good idea)
or if you want to have the convenience of stable fuel ready and waiting for an emergency ( you will still probably need gasoline to start the generator before turning on the propane but not much of it )
or if want to have a cleaner burning generator that puts out less toxic exhaust into the air your breathing then YES propane is worth it.
If you have never started your generator or used it once since you bought it 4 years ago etc. perhaps the Propane conversion is not so worth it for you.
