Originally Posted by MN Renovator
Where is the moisture coming from? Is this an Alaska problem? I had a turtle vent that leaked in a little water, problem during a hard rainstorm that cause there to be a frisbee sized section of cellulose that caked up slightly but running my hand through it thoroughly broke it up and it only went about 1/4" deep. Is this on the top layer of cellulose or do you have a bunch of moisture coming from the interior of the house?
From what I could tell it was years of the air in the attic hitting the dew point both from inside air escaping and humid outside air coming in the vents. The moisture would condense in the cellusose and saturate it so it would settle a little more at the time. It went from light and fluffy to a hard biscuit.
Erich
