Originally Posted by MN Renovator
Erich, Please explain why you don't like cellulose. For the cellulose you removed, what is its replacement?
MN,
I have a problem with cellulose because of how it soaks up moisture and turns into a brick and then damages your ceiling drywall. This happened at my last home. Any condensing moisture affects the cellulose. You can see in my video how difficult it was to remove the cellulose. I had to chip it out with a garden tool.
I blew in AttiCat as the substitute for cellulose.
Erich
