Old 08-02-16, 07:46 AM   #12
Hey JR, If you ever remove the side panel and run the unit..
Be aware that it might short cycle and keep going into defrost mode.
I had the side cover off mine, and noticed the accumulator got really cold on the bottom,
and was pretty normal on the top. (Top 48F, Bottom 8F).
The bottom is near the defrost sensor, and the low pressure starts defrost.
It shuts down the compressor. When I started to replace the cover, when the unit was running,
It almost sucked the cover out of my hands! It slammed into place..
I didn't even have to hold it, while putting in the 6 screws..
That cover HAS to be on, for the unit to operate normally.
(Note: This unit is not completely normal, since it's not running at spec).
The defrost sensor is in the middle, to the left of the accumulator tube, wrapped in insulation. (wire coming out of it).
