Old 07-31-16, 08:39 PM   #11
Default Santa Fe Classic
Wow, 24 deg F is a lot! Mine is only running a 9 deg temperature gain.
From what I've read so far, I think the pints per day spec might be the same
on both the R22 and R410a Santa Fe Classic units.
So the temperature gain might be similar.
I'm going to see if I can find some more data on the R22 unit online.
Since the target Superheat data doesn't seem to be available, maybe using
the I/O temperature gain will be an alternative way to add some R410a to the unit.
I can't believe how heavy it is! Getting it down to the basement was a task and a half..
Thanks for the info!
