The light you linked to is a motion sensor light. Neil has pretty much got you lined out. That bulb runs on AC. As he said you would need a very small inverter to turn the DC from the batteries into usable AC for the bulb. There are a number of other lamp solutions out there that do exactly what you want but not with that housing. If you must use that housing you will need the solar panel, a battery pack, the battery charge controller, an inverter and probably a small enclosure for the electronic items. You might try to find a direct DC LED bulb that will fit in the housing, remove the AC socket and find a way to mount the DC bulb. That would eliminate the need for an inverter.
Something like this could work.
https://www.amazon.com/GLW-Waterproof-Outdoor-Security-Equivalent/dp/B00DI3N0QM
JJ
