I do the same thing as hamsterpower. However, my house is not exactly leak proof, so its no big deal. I think if you had a tight house it wouldn't be a good idea, but if you have a tight house you should also have an HRV which should take care of it. Perhaps you could use a fan to cycle air into and out of the bathroom into the hall instead of outside?
I do have a dehumidifier for my basement though. I'll bring it up and run it while I shower to see how it does. I'll also plug it into the kill a watt and see what kind of power usage is there.
