Putting radiator in front of mini split
Alright . Today . I checked with a sprinkler set it to spray on the mini split coils outside . It dropped the exhaust heat from 115 degrees . To 88 degrees . That was about 20 minutes .Believe it dropped it 400 watts i cant remember. So instead of spraying it in and all over the coils . I want to put a radiator in front of mini split intake and run the cold well water through it to help drop the intake temp and raise efficiency of my mini split . I am on a well. Not city water. Any ideas of ways to do it . For now itd be a open loop . Then i will make it like a closed loop for winter to increase my heating efficiency. Any one got any ideas of how to do it .
