pinballlooking,
Will the Volt charge the traction battery while running on ice (internal combustion engine)? The Prius is built to do that. I can charge while driving. I was told the Volt can't charge traction battery while driving only from an outlet. That's why while driving on ice the mpg drops to around 32 and the Prius is still getting 55 to 60 mpg.
Vern To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
