Old 11-05-10, 02:32 AM   #3
Piwoslaw
Piwoslaw's Avatar
Originally Posted by obxdave View Post
I heard that you could use a frig to chill water to run though a water to air heat exchanger does any one know of this thank you for your help
Yes, you can do that, but it would be more efficient to delete the water part and directly chill the air. Plus, as Ryland mentioned, you'll have some spare heat to deal with (in fact, you get more waste heat than you get chill), so if you divert that to your hot water tank then it'll definately be worth it.
