Thanks for the ideas guys! I'll try to adjust the delta on my thermostat if possible. I'm sure that will help. I also looked into the heat manager that XRinger recommended. I really like that idea. It looks like an arduino, temp sensor and a relay. I've built a project very similar to that before. I think my aquastat is one of the super old kinds that only has a high temperature limit. I might look into replacing that with a newer one if possible also. This has produced a lot of good ideas!
