Originally Posted by Mikesolar
The sketch is not important...
If I understand your post, you are having problems with your sketch. So, it seems that since you are having problems with your sketch, it actually is important... especially if you want someone else to help you. The de-bugger in Arduino is not the best in the world, but it is better than nothing. Sometimes there is an error in some part of the code, and the Arduino de-bugger says it's in another place, so if you do not include your entire sketch, you are wasting everyones time.
It is easiest to see your sketch, if you put it inside CODE tags.
So you would use a square brace "[" and then you would put the letters "CODE" next, and then you would put another square brace "]"... then you put your sketch, your whole sketch next...
...then you would use a square brace "[" and then you would put a slash "/" and then the letters "CODE" next, and then you would put another square brace "]".
It makes your sketch stand out so that it's easier to see what went wrong.
