Funny I had to fine that tool also. If you can find it you can use a very large
Philips screwdriver but the tool works much better.
12.5 kW array we generated 1,645 kWh August 2018
August 2018= 1,645 kWh
August 2017= 1,717 kWh
August 2016= 1,716 kWh
August 2015= 1,873 kWh
August 2014= 1,915 kWh
Highest one day July 2018 = 72.9 kWhs
We have now banked 1,727 KWh for the winter.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
