Old 12-26-21, 11:44 AM   #97
pinballlooking
pinballlooking's Avatar
I paid extra for the bidirectional thermostat. That has all the loop temps the before heat exchanger after heat exchanger.
It has the before after to the holding hot water tank.
Without this info you have no way to trouble shoot if there is an issue.
The only thing I dislike is they did not offer a Wi-Fi thermostat. I can put one in I even bought one to put in but I lose all that great info.
It is not worth loosing that info to me. With Geo we really do not do setbacks we just set it to one temp and let it run.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
