Originally Posted by Kaylee
For the majority of DIY hydronic underfloor heating installations, it is important your licencsed plumber test that the pipework has been installed correctly prior to the screed being laid. Testing should be carried out at 2 bar for 10 minutes and 10 bar for 10 minutes. Your plumber should also connect the services to the boiler.
Howdy Kaylee,
When you say 'underfloor', do you mean tubing at the bottom of a slab, or do you mean tubing underneath the sub-floor?
