Old 03-01-21, 05:38 PM   #8
pinballlooking
pinballlooking's Avatar
I really can’t wait to take off the head off the compressor and see what it needs.
But I want to run it before I do this. My motor bracket comes in on Wednesday.
I looked over the weekend and the old brackets were not even close enough to test it out.
I will have to line it all up to mount the new motor bracket.
I can turn it over by hand and feel it putting out good air flow.
If you need Quincy documents you can get them here.
Resource Library:
https://www.revbase.com/TagTeam/Clie...&siteid=841396
Most of the the links on the net are bad they moved where the store the old manuals links do not work anymore.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
