Old 11-29-13, 07:20 PM   #24
Originally Posted by Servicetech View Post
Does the thermostat use mechanical relays for switching the outputs? Do you heat a click from the thermostat when the system comes on?
I checked this out today. There are no clicking noises from the thermostat that I can hear when the heat kicks on/off. That isn't to say its not using a real small relay though. I think the spec sheet says that each pin can only carry 400mA.
