Old 10-10-08, 07:12 AM   #5
This is the quote from the FAQ.
Can PEX be used for aboveground outdoor applications?
No. PEX is currently designed for indoor and buried applications only and is not recommended for outdoor, aboveground use. Short exposures to sunlight during construction are permissible, but should not exceed the manufacturer’s recommendations. PEX should be stored under cover, shielded from direct sunlight or in the original packaging. In the future, PEX products rated for outdoor use may be developed.
The thing is, in the design, the PEX is covered with either aluminum sheet or paint. The aluminum for sure is going to block any sunlight from degrading the PEX. The paint may not be the best blocker for sunlight, but its still not in direct light. That, or it could be covered up with something else (more aluminum perhaps).
I'm not saying the design is perfect. But, I do think you could make it totally workable and reliable.
