Old 12-05-17, 02:58 PM   #643
pinballlooking
pinballlooking's Avatar
12.5 kW array we generated 1,821 kWh Oct 2017
We made 296 more kWh than we used.
Oct 2017= 1,821 kWh
Oct 2016= 1,732 kWh
Oct 2015= 1,347 kWh
Oct 2014= 1,668 kWh
Nov 2017= 1,196 kWh
Nov 2016= 1,333 kWh
Nov 2015= 955 kWh
Nov 2014= 1,348 kWh
We still have 1,203 Kw banked for the winter.
I have one micro inverter that is working but it is 20% below what it should be making.
I got a RMA number today and Enphase is sending out a new one to me. I have a spare I will install and use the one they send me as the spare. This is my first issue with the array since the install. Without per panel monitoring this would not be detectable.
Other solar producers show us your numbers when you have them.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
