Old 02-12-17, 08:24 PM   #1
Default Need advice about Cat 6 running parallel to unshielded Romex...
Anybody have any code or experiential advice about running Cat 6 Ethernet parallel to unshielded Romex?
The parallel run will be about 16 ft.
I've seen a lot of opinion but little code on such a thing.
In one UK post, citing code said to keep the runs separated by at least 2".
An opinion said they should each be metal shielded and no less than 12".
Quite a bit of variation there.
Thanks...
