Old 10-09-19, 05:42 PM   #3
MN Renovator
MN Renovator's Avatar
The entering air of an AC condenser being 65 degrees instead of 90 degrees doesn't reduce the power consumption by that much. My compressor uses about 2200 watts with a 90 degree entering temperature and 1900 or so with a 65 degree entering temperature and the output capacity at the evaporator is more but the total likely doesn't end up being more than about 15%.
The best source of information for entering condenser temperature, power usage, and output with a TXV driven unit can be found from HVAC manufacturers information. Goodman has a solid product specification sheet for their units.
https://www.goodmanmfg.com/pdfviewer....pdf?view=true
One more important factor - An AC condenser requires unimpeded airflow, they can't handle much static pressure without losing flow, if you are adding a blower to push air through an earth tube, you MUST add that power back in, which could cause a net loss in efficiency.
