If it's 99F in the garage, I'm sure the A7 could make abundant hot water..
Plus, it should cool down the garage a bit too. (Until the storage tank got hot)..
If you wanted to work in the garage, I would consider insulation and buying an
inverter mini-spit AC (or AC+Heat model).
