Old 05-04-20, 12:38 PM   #4
pinballlooking
pinballlooking's Avatar
I have one on order. I will use this to show how much power my shop is using. The solar is over the shop so it will not be 100% accurate but better than what I have now. I can start making the shop pay is own power bill.
I sent them a email about solar.
"The Vue is capable of net metering solar generation. The two 200A sensors that ship with the Vue are directional and can measure any energy that is generated in excess of your consumption - as long as the sensors are installed between your utility meter and the solar input to your system. You can also use the 50A sensors, these are NOT directional, that come with the Expansion Module to measure the amount of energy generated by your solar system."
My solar is on a 70 amp breaker the goes to a sub panel.
The directional power will help me know how much power my shop is using.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
The Following 2 Users Say Thank You to pinballlooking For This Useful Post:
creeky (06-12-20), Daox (05-04-20)
