Ok, so is there anything in the space above the kitchen cabinets? It looked like the drop ceiling in the hallway starts about the same place. Then again, that makes too much sense. Why not run stuff so its impossible to service? No matter, just mod the system outdoors where you can reach everything important.
With the 6 ton unit, you could either swap out the whole txv, try the one that's installed, or just change the orifice. Depends on a lot of things.
