Old 10-30-13, 07:34 AM   #25
I would only heat the basement on "low humidity days" per above.
My RH sensor tells the CAI when it's okay to run the blowers.
I'm not worried about too much heat from the basement over-heating
the living area, since we never cool the house below about 74F anyways.
The 'heating' temp of the basement could be set to match the temp of the living area.
The ridge vent is new. The roofer sawed a ragged slot down the peak and put on the vent cap..
I didn't really want it, but somehow ended up with it anyways. Jacked up the cost? Yeah!
Since this house doesn't have any ventilation soffits under the gutters,
(Except on the den, a new addition) we are used to getting ice dams
when the conditions are there. Snow and rain, followed by rain or melting
followed by low temps.
We have heating wires installed on the north side roof, where the sun is blocked
during winter's low sun angles.
