Old 02-22-14, 11:47 AM   #24
BeerGrylls
Many thanks for the input Mike. It is good know, however what if the coil becomes an evaporator ? I actually try to refrain from using those designations since they switch around. My outside hx will also be used for cooling/dehumidifying, therefore there will be gas flowing through it too, not just liquid. Should I still be concerned ?
BeerGrylls is offline   Reply With Quote
