Originally Posted by Acuario
I know it shouldn't affect the operation as it's IR, but have you tested in dark conditions? Sunlight (as you stated) will probably affect it.
Acuario
The Sanyo is definitely in the open, where my coil is entirely within a cabinet and only subject to reflected light, if at all. I think the tuning can be made to avoid it but it needs to be quite precise which is why 2 parallel systems might work. Temp measuring to determine turn on and IR to determine when it has defrosted, for example.
