My 4.4KW array:
August 2018: 553kWh
August 2017: 547kWh
August 2016: 526kwh
August 2015: 489kWh
August 2014: 566kWh
August 2013: 603kWh
Thank you Pinball for posting the details on inverter replacement. I finally went up on the roof today to swap out my M215 that was replaced via RMA months ago. The swap was painless after I located my enphase tool, an 11mm wrench and a 90° Phillips screwdriver. I replaced the defective unit with the next lowest serial number unit in the collection of M215s I have for my next install.
