Old 09-03-14, 12:31 AM   #17
Ryland
Motors often have a continues and a peek hp, gas engines are rated in peek hp.
Motors almost never list their peek hp as their rated hp.
If you can, wire that motor for 240v, even if you use the same 12 gauge cord, you will be producing less heat in the cord and having the voltage drop less, allowing the motor to do more work per watt pulled from the wall.
The Following User Says Thank You to Ryland For This Useful Post:
Daox (09-03-14)
