Originally Posted by Daox
Is it just me, or does a 600W constant draw seem pretty high? What do you have running constantly that adds up to 600W?
Today it was 640W as I forgot to switch off the lights outside as explained above. Tuesday it was 460W which roughly matches what I regularly see and I described in the following link :
Denis.
Earth absorbs 1.8 t CO2/head/yr, while a French generates 6.2 t CO2/yr To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.- kg saved 06/08-08/09: 1816.9+382.9 (ecodriving / 1420mi not driven) = 2199.8
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. (2.66 kg/l diesel)
- kg saved by 3kWc photo-voltaic solar panels : 187 kg/yr
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. (59.1 g/kWh)
Radioactive wastes saved by 3kWc photo-voltaic solar panels : - Long life (>100,000 years) : 2.85 g/yr (0.9 mg/kWh)
- Short life (<300 years) : 31.7 g/yr (10.0 mg/kWh)
