You could use fresh water as long as the hole didnt take that long . Id recommend recirculating it that way you dont fill up the hole your standin in. When your done make sure have a barrel in the other hole to catch all the circulated mud . So you can use it to do another length . Or if your done just fill up the other hole with the water and pull your barrel out.
