Old 01-13-21, 12:02 PM   #21
Wanna Beco
So for some reason on my power companies website, the comparison page is missing. In dollars though, my bill was $90 Less this month than January of 2020. ($200 vs $112)
Now you may be thinking that we must have a sealed house. That is not true and here is why. We have not turned on our HVAC for a few months. NO HEAT! And that is what is so frustrating about this month's bill. That $112 bucks is all plugins. I can not really control for that with insulation.
My big expense is my hot water heater. I actually bought new insulation for it last month and rewrapped it. I did not have my sense last Dec. so I do not know what it was using. This billing cycle though it used 200KWH!!!! That alone is 24.5 percent of my electricity for this month. Now usually is uses around 3 kWh a day. I keep an eye on that as it is older. Well, yesterday it used 6.5 kWh. It has never used that much in one day.
The unit itself is 9-10 years old. Last January I cleaned it out and changed the elements. I am going to clean it out again, and I think I will switch the elements as I know the bottom one does most of the work (I think) Either way I think switching them during a service is a good idea. My Anode rod seems to be on the outlet line. I have never changed ANY anode rod before, but this one seems tricky. The videos that I watch all have the anode rod that is separate. Also, I know that I will have to cut the old rod with a grinder and the new one will have to be segmented so it can go in because I have very little clearance above the tank. Anyone ever done this before with this type of system?
Anyway that is my update
Wanna Beco is offline   Reply With Quote
