Originally Posted by Daox
Me and GaryGary shared emails about this. We think that if you could find a way to cutoff the attic vents to warm things up this would be possible. However, you still have to deal with the humidity in the air and that may cause issues. So, you'd need some sort of automated vent system and it would likely be complex and costly.
If your attic vent openings were no larger than about 12x12", then you could put on some regular air registers with a manual adjustable damper as integral , that you could open and close using something long from the ground . But, i doubt it would help that much. The solution would be to cut out a large section of roof and fit a Solar Collector over the opening on the southside of the roof keeping it covered up in the summer months....but now we are getting a little outrageous for most people. lol...
