Old 05-06-20, 05:57 AM   #6
jluther23
This may be a little late, if you already have a solution. If you are in to DIY projects you need to look into software called Home Assistant. I use it with a raspberry pi to monitor temperatures at different areas to either send alerts or turn on and off heaters. You can build your own sensors very cheap and programming the sensors is easy with the instructions on the home assistant website.
jluther23 is offline   Reply With Quote
The Following User Says Thank You to jluther23 For This Useful Post:
mechanic (05-06-20)
