Old 10-30-13, 07:59 PM   #81
Hv23t
Hv23t's Avatar
You should read this post...
...It is about your water heater hack.
Seriously,
Yeah that is good info. On my setup I'm not using it to seal in the refridgerant. I'm using it as a bulkhead fitting to keep the water in the tank and allow the hx lines to come out/in.
I know I havnt updated this thread in awhile. Mainly because there isn't much to update. It's been about 11 months since I've installed it and it's been pretty much flawless. The kill a watt is estimating 184.21 for a year. If I get time someday I'd like to add a air temperature controlled fan to vent the room when the outside air is warmer than the inside. In the summer is stays really cold in there lowing the efficientcy.
Hv23t
Hv23t is offline   Reply With Quote
