Yesterday I finished up hole number 11 of 16.
I thought I'd summarize what I have learned so far about this process. I'd be very surprised if anyone experienced soil conditions exactly like mine. I'd be much more surprised if no one had any of the experiences I have had.
So I offer the following information in the hopes that at least some of my experience can be useful to those who might want to try to make their own loop field.
Here is a diagram of the soil conditions I have encountered in every hole I have dug:
TOP 2 FEET - sand/clay/organic bits
The top two feet I initially started with a shovel and a pointed steel rod, to loosen things up. At first, just tossed the dirt on the ground near the hole, not realizing just how much was going to come out of the hole (and also not realizing that it would all have to go back into the hole). On subsequent holes, I used a 55 gallon barrel to hold the dirt while I was digging. This makes is very much easier to get the dirt back in the hole.
In my experience, roots are a problem in the top 2 feet but really not much of a problem any deeper. I started using the Shop Vac on the second hole to remove debris, and it really helped in dealing with roots, as once the dirt was vacuumed away from the root, it became very apparent exactly where to cut to remove the root.
I tried hacking out the roots with a sharpened cold chisel welded to a section of water pipe, but it didn't work nearly as well as going in with a reciprocating saw.
The top two feet were very easy to get through, the soil was sand and clay, but there was so much organic matter mixed in that the soil was 'light' and easily penetrated.
2 FEET TO 6 FEET - clay to clay/sand
This was the toughest layer to get through. The clay was pretty dry and hard. Initially I tried just a hand auger. It was slow, exhausting work. Using a pointed iron digging bar to loosen things up a bit, ahead of the hand auger helped, but it was tough work.
I tried various diggers and bits on my electric auger, with better results, but only 1/4 horse power, it could only push a three inch bit (see photo above) about a half a foot into the clay, after which I'd have to bash away with the pointed steel bar and vacuum out the debris, and back to the electric auger, etc, etc, etc. On every hole, there was a particular layer of clay at about 4 feet deep which was very tough and it took at least an hour of drilling and bashing and vacuuming to advance six inches.
So I got my hands on a 5.5 HP post hole auger and drilled out the remaining holes to the depth of the auger bit, about 36 inches. I also had Howard-the-machinist make me an adapter so I could put on an extension and drill deeper.
To my disappointment, the post hole digger didn't exhibit the advantage of power I had expected. I tried putting water in the hole a couple of days before drilling, but when I hit the tough layer of clay, it wasn't just tough but it was tough and slippery.
I tried a smaller diameter post hole auger bit and that did help in some cases, but not all.
It seemed that the ultimate approach was drilling, bashing with the pointed iron bar and vacuuming, and repeat, and repeat.
I did make an improvement to the electric auger which has helped, and that is I added an electric wench to the drill stand. A 120 volt wench would have cost me about $100 + bucks, but I got a 12 volt model on sale for $50. I had a spare 12 volt deep discharge battery laying around and a battery charger, so it was pretty easy. The real reason I added the auger is that the manual wench had open gears and I came very close to getting my fingers in the gears more than once. I have been playing guitar most of my life, and I have grown very fond of my fingers.
Also, the last time the finger tips nearly went into the gears, I did a hasty calculation of what it would cost to take a trip to the emergency room, and compared that to the $50 for the wench, an I found myself driving to the store to get the wench.
[* Drilling Report Aug 31, 2009 Part Two to come... *]
Regards,
