The main problem I had, was placing the site. because of all the shadows, in the back yard,
I went with a movable tracking mount for a small solar array.
http://ecorenovator.org/forum/projec...project-7.html
I plan to move the whole thing around to find the optimum location.
The steel rails that I used,
Super-Strut B1400HS might be very useful
for installing panels on a roof. And they are much cheaper than Aluminum.
And you can get 1/4:20 Nut-plates that fit inside the rails.
I ended up using 4 rails, but on a roof or any fixed surface (that didn't flex),
2 rails should work fine.
