Old 07-02-15, 02:22 AM   #1
Acuario
Question Best configuration for double panel hx
Hi,
I'm after some advice.
I have what is effectively a double panel air to water heat exchanger that is used to heat/cool a house via air ducts. The unit has a fan that draws air through the exchanger and blows it from the room vents.
What is the best direction for water vs air flow - the uncooled air passing through the coldest panel first, then the warmer panel or the reverse?
Acuario
Acuario is offline   Reply With Quote
