Sounds like an idea with merit.
Are the ducts on the internal or external walls?
What about the vents, are they floor mounted or at ceiling height?
As I was reading your post I was imaging a solar chimney type system, although I'm not sure how that would work over 3 levels. For cooling it would be easier. Heating might be a challenge to get the heat down to the lowest level.
