Thread: Eco-Garage
Old 03-06-09, 08:13 PM   #13
dremd
Need More Eco
dremd's Avatar
Send a message via AIM to dremd
Traditionally, PEX tubing is used in hydronic heated floors. You simply lay out the tubing and poor the cement right over it. Very easy, and the tubing is flexible and should handle cracking.
The collectors could literally go anywhere in your yard, it doesn't have to be on the building.
I also agree with truckncycle, make it larger!
You NEED to insulate to slab fro the ground. I've read a few threads where people failed at insulating the slab and were just pumping heat in to the ground.
dremd is offline   Reply With Quote
