Pop in and look at the "AirScape" site that appears on your post. The photos and descriptions should provide some ideas and inspiration.
Also, if you can find an opportunity to look in/at some commercial or industrial air handling equipment you may also get some ideas. That industry uses a wider selection of equipment, and combinations of equipment than is normally seen in residential installs. Most residential equipment has a "consumer packaged" kind of character about it, many parts are not interchangeable, and they may be "multitask" in nature.
As far as the aesthetics of your roof top equipment, maybe take another cue from the commercial industry: cosider installing a privacy panel or valance in front of your equipment, picking up on styling elements from the rest of your house. The shade from the panels may be helpful to the operation of your equipment as well.
